Parametric sketching
stephenP66RM
Message 1 of 11
stephenP66RM
One of my most common tasks is drawing cutting tools, which has a certain amount of fixed geometry and variable geometry rotated in an array. If I were using CATIA it would be simple enough to draw a sketch with parametric dimensions and create the model that way.  However, I am using AutoCAD Lt, which if I understand correctly, doesn't have the ability to use parametric dimensions.
Having said that, I notice that every time I go into Block Edit there is a palette with a few tabs which include the word Parameters, so I'm hoping that there is a way of using it in some form or another to help speed up the design process.
Is it possible?  And are there any tutorials to help me get the most out of the Block Edit function?
Many thanks in advance,
Stephen
Replies (10)
Message 2 of 11
h_s_walker
Unfortunately not.
LT can only view or edit parametric objects which have been created in full AutoCAD. It cannot create parametric objects on it's own
Howard Walker
Left Handed and Proud
Message 3 of 11
stephenP66RM
That's frustrating.
Is the palette only there for editing parametrics created in full-fat AutoCAD, or can it be used for other things?
Message 4 of 11
h_s_walker
It can be used for changing the order of Attributes / Parameter sets that you place in the block.
Howard Walker
Message 5 of 11
stephenP66RM
Do you know of any tutorials on what you are describing? I've never come across attributes within blocks, so whilst it might not help me with my current needs, it might be useful to know in the future.
Message 6 of 11
steven-g
For clarity LT cannot edit the constraints themselves just the objects that are constrained. It can delete them, just not create or edit them.
Message 7 of 11
cadffm
You can use action-parameters, thats what you see in BEDIT.
Full Autocad have constrainParameters too.
For the first Steps: Youtube
Autocad dynamic Block
But there is nothing for polar-array parameters.
Do you know about the normal ARRAY command? F1
An example File for us forces a better help for you!
Sebastian
Message 8 of 11
h_s_walker
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Howard Walker
Message 9 of 11
steven-g
Well I'm confused now (it doesn't take much), are we talking Block Parameters or Geometric Constraints, because Block Parameters are IN and Geometric Constraints are OUT (other than viewing).
Message 10 of 11
cadffm
My opinion
The ThreadOpener does not know the possibilities in LT and the full version.
But in BEDIT he sees only the palette for action parameters, so they are meant and available in LT.
Which is more sought for the work are constrained-parameters, but these are not available in LT.
So he can check the possibilities of action-parameters in dynamicBlocks, perhaps it could help,
and command ARRAY for polar-copies which can also be changed by values.
If he is looking for tutorials, he should take care in Tutorials when examples used constrained parameters,
then this example is only for the Fullversion of AutoCAD.
Sebastian
Message 11 of 11
pendean
Community Legend
Community Legend
Autodesk INVENTOR (possibly INVENTOR LT) is comparable to CATIA: if it has to be "AutoCAD", AutoCAD MECHANICAL is the closest comparison. Full AutoCAD, not AUTOCADLT, would be the next lwer ability comparison.
Did you possibly need to be using INVENTOR/LT perhaps https://www.autodesk.com/products/inventor-lt-family/overview
