- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
One of my most common tasks is drawing cutting tools, which has a certain amount of fixed geometry and variable geometry rotated in an array. If I were using CATIA it would be simple enough to draw a sketch with parametric dimensions and create the model that way. However, I am using AutoCAD Lt, which if I understand correctly, doesn't have the ability to use parametric dimensions.
Having said that, I notice that every time I go into Block Edit there is a palette with a few tabs which include the word Parameters, so I'm hoping that there is a way of using it in some form or another to help speed up the design process.
Is it possible? And are there any tutorials to help me get the most out of the Block Edit function?
Many thanks in advance,
Stephen
