Parameters in Model Space: Change multiple from one spot
Is there a way to have a list of parameters that when one of the list items is changed, it updates all attributes/text that contains that parameter?
For example, I have a drawing that contains blocks of my company's custom page borders. The way we plot drawings is we have the title blocks lined up in model space, then we viewport the title blocks into a paper space layout, with another viewport inside the title block which shows the model. There tends to be multiple page sizes within the same drawing that require different-sized title blocks. I want to be able to change the date in all of the blocks without having to select an instance of each size of title block then SELECTSIMILAR then changing the common attributes.
