I am having trouble with panning. I have checked the MBUTTONPAN command and set it to 1. It's on. But it still sticks. I may try getting a new mouse.
What and where is the registry they mention in the below post??
But in the meantime I googled the issue and found this also:
Alternatively, you may use the . reg file attached to this article. Download the ZIP file, extract it, and then double-click the . reg file to apply it to your system.
It is slow, like that it gets stuck and I have to keep doing pan to get it to pan. Otherwise the mouse works fine. Maybe the center button (pan) is wearing out? I've replaced the battery in case.
When I looked up "middle button pan issues" I found the info I copied in my original post and I realized that with two drawings open, I had indeed seen the status bar flicker, etc. See link below. This only happens if two drawings are open at the same time. Thus my question also about what and where is windows registry? Never heard of it.
Autocad LT 2014
Windows 7
Yes, things could have changed but I am not sure. My computer does windows updates at night.
