Opening in multiple windows instead of tabs (2023)
amandaVNANM
Message 1 of 26
amandaVNANM
I am trying to open multiple drawings in one window but when I click a drawing in file explorer while already having AutoCADLT open, it will open a brand new window instead of a new tab in that existing window.
Replies (25)
Message 2 of 26
h_s_walker
At the command line type SDI. Change the value to 0
Howard Walker
Left Handed and Proud
Message 3 of 26
amandaVNANM
it is already set to that, still opening in new windows. TASKBAR is also set to 0.
Message 4 of 26
h_s_walker
Have you updated the latest version of AutoCAD?
What version of windows are you using?
Ah looks like there's a new "SDI" command in 2023. I can't find it at the moment.
EDIT: @amandaVNANM looks like the value should be 1 and not 0
Howard Walker
Message 5 of 26
amandaVNANM
I just downloaded 2023 (per the title of this post) today. I do not have any updates
Message 6 of 26
amandaVNANM
Changed the SDI to 1 and still doesn't open in one window.
Message 7 of 26
pendean
Community Legend
Community Legend
You need to do this after LT2023 installs, it breaks it for some unknown reason and why you get what you get https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/DWG-file...
"Solution:
To associate DWG files with AutoCAD DWG Launcher ...."
Message 8 of 26
amandaVNANM
It is now giving me this message since our files were made with 2022 and I uninstalled AutoCAD 2022.
Message 9 of 26
pendean
Community Legend
Community Legend
You have to open LT2023, open a file, do "something", close the file, close the LT2023 program, then DWGLAUNCHER will work just fine.
FWIW you should never EVER remove an older version of AutoCAD/LT until you are 100% positive after a month or three that the newer version is working perfectly 100%. A lesson we have all learned across the years.
Message 10 of 26
amandaVNANM
nope, I did exactly that and get the exact same error message.
Message 11 of 26
amandaVNANM
so I re downloaded 2022 and when I do what that post says, it only opens in 2022 and not 2023
Message 12 of 26
amandaVNANM
it looks as though there is not a 2023 autocad launch, only 2022
Message 13 of 26
pendean
Community Legend
Community Legend
Weird indeed: I am not having that issue here in Win10 and LT2023 (and I have LT2022 and T2021 on the same computer).
Message 14 of 26
amandaVNANM
yup I have Win10 Pro and re-installed the 2022. I guess I can wait till the first update and see if it can be fixed!
Message 15 of 26
pendean
Community Legend
Community Legend
You can also start a support ticket through your subscription portal as explained here to report the problem, they might has a fix or workaround in the meantime https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
Message 16 of 26
amandaVNANM
i will try that, thank you
Message 17 of 26
amandaVNANM
I did this again and it works fine now. I don't know I did different but it works and that's the most important thing haha
Message 18 of 26
iant123DM83S
That worked. Love my Tabs - Thanks!!!
Message 19 of 26
echarrison
It seems I can't get this working. I tried the SDI command line and going into the properties and changing the default app. Other than contacting support, anything else?
Message 20 of 26
pendean
Community Legend
Community Legend
@echarrison explain in more detail how exactly you are opening DWG files, what is your OS, and what year-version is your AutoCAD/LT please.
