OLE Object won't update when I make changes in Excel
Process: I copy a section of an Excel sheet and choose 'Paste Special' in AutoCAD. Then I check off the 'Paste Link' button and Select 'Microsoft Excel Workheet'.
Issue: When I save changes to the excel sheet, they are rarely updated in the AutoCAD file.  Sometimes the changes do update in AutoCAD, but I don't know what I've done differently for it to work.
Does anyone know why the changes won't update?
Thanks!
jayhar
<<<Process: I copy a section of an Excel sheet and choose 'Paste Special' in AutoCAD. Then I check off the 'Paste Link' button and Select 'Microsoft Excel Workheet'. >>>>
OK, fine
Did you try OLELINKS in Autocad, On Menubar > Edit > OLE links > Select type > Break Link.  its does not work
do Update Now.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Micros...
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
