Ole Object Highlighted Section Not Plotting The Color
jpateQ5L7E
Message 1 of 13
jpateQ5L7E
When I add an Ole object to a CAD drawing (Excel, Word doc) and I high light a section of the document, when I plot it, the highlighted section doesn't show. I've checked the Plot Style Table (monochrome.ctb) settings, but still nothing. Thanks in advance for any help.
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
Plot Style Table settings have no effect whatsoever on images in your DWG file: they only affect AutoCAD Objects.
your image must contain whatever you want it to print from the source of the image.
Message 3 of 13
jpateQ5L7E
What I'm doing is in CAD going to Insert/OLE Object/Microsoft Excel Worksheet. I add the data to the Excel Worksheet and highlight a couple of rows. In CAD, the image shows the highlighted rows, and when I go to plot it, I can preview it and it shows the highlighted rows, but when its plotted, the highlights are gone.
Message 4 of 13
paullimapa
Have you tried plotting a PDF using Dwg To Pdf.pc3 ?
Paul Li
IT Specialist
@The Office
Message 5 of 13
jpateQ5L7E
Just tried it. Same results.
Message 6 of 13
paullimapa
Do you have the latest LT updates installed? Enter ABOUT command, do a screen capture & post that here
Paul Li
IT Specialist
@The Office
Message 7 of 13
jpateQ5L7E
Yes, I just got a new computer about a week ago, and installed CAD from the website. I was having this issue with my other computer, but just lived with it. Figured I'd throw this out and see if someone had a fix.
Message 8 of 13
paullimapa
Still doesn’t mean you installed the latest AutoCAD LT updates
Paul Li
IT Specialist
@The Office
Message 9 of 13
pendean
Community Legend
Community Legend
Thanks for the screenshots: you want to change this from MONOCHROME to...
Then your OLE will print in the color it is in the source file.
Message 10 of 13
pendean
Community Legend
Community Legend
It does do that for most users since the last year I believe
https://manage.autodesk.com/products
pendean_0-1713557038538.pngpendean_1-1713557056934.pngpendean_2-1713557071816.pngpendean_3-1713557088957.png
Message 11 of 13
jpateQ5L7E
That did. Thank you so much. I knew it was going to be some setting that I was missing.
Message 12 of 13
jpateQ5L7E
Thanks. I will double check this. My original issue was resolved by pendean's comment. Thank you again.
Message 13 of 13
jpateQ5L7E
Thanks again for your help.
