03:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am new to Auto cad and self teaching my self from scratch , so using tutorials on you tube , I am using the 2019 cad light version , my question is (there will be many more) about the offset button when i draw a circle or a triangle or similar i use then the offset button to repeat this at a given distance , in the tutorials it shows this very easily but the problem i am having is that when i select my off set the try to select where i would like it to be off set the rectangle circle deletes if I want several off sets they appear but the original disappears , in the tutorials which are from earlier versions of cad do not do this ?
