AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
object enablers for autocad lt 2013 for macs
5 REPLIES 5
789 Views, 5 Replies
When using a survey drawing as a background in my autocad lt 1013 file, the contours show up at big rectangles. I believe I need Autocad Civil object enabler. I've found a freeware application, but it appears to only be for Windows and I'm using a mac.Is there a fix or a way around?
See link: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19052749&linkID=9240818
5 REPLIES 5
pendean
You're out of luck with the MAC version: ask the Civil user to 'export to autocad" and send you a 2D version of their file to use.
in reply to: pendean
As I feared, but thank you for your quick input! Surely I can't be the only one with so basic a problem, so hopefully a fix is in the works.....
pendean
Agreed: just realize that LT in general, Windows or Mac, seems to get shorted on Object Enablers.
Keep an eye on the MAC forum here, not this LT for Windows forum you are posting in, for any changes or additions to your variant: http://forums.autodesk.com/t5/AutoCAD-for-Mac/bd-p/520
do you know if Full autocad 2013 for mac has same objects issue's?
pendean
Most likely: Ask in the MAC forum to confirm.
”Boost
