Notes & lines dont appear when in model & paper space but will print hard copy
Whilst the AutoCAD LT 2016 package is operating there appears to be an issue with what you can see on the screen (when in paper and model space) and when using ‘print preview’ when plotting (many notes and lines not showing but will print out on hard copy).
Any ideas
Kind regards
Andrew
h_s_walker
Welcome to the Forums
Can you post screenshots of what you are seeing / not seeing
Howard Walker
Left Handed and Proud
pendean
Community Legend
Community Legend
Show us your DWG file and a PDF print that display the problem please.
Firstly apologies for the delay responding and thank you in advance for trying to assist.
I will attempt (I'm not very good with PC's!) to attach the 'dwg' file of one of the drawings the issue occurs (currently all drgs I go in have the same problem).
If you go to plot say using 'pdf creator' and preview the drawing, the notes and title block borders (set in paper space) don't appear but will print if you do a hard copy.
If you go into model space some of the lines, shading, etc, do not show but if you really zoom in the they will appear.
I previously had AutoCad LT 2015 which had no issues and after downloading the 2016 version the problem has now appeared? Please note the old AutoCad LT 2015 has not been removed from my hard drive if you think this may make a difference?
Any suggestions would be very welcome.
Thanks again
Kind regards
Andrew
