Hi All,
I normally open my AutoCAD files from Excel using the below by
Dim acadApp As Object
Of late I have been using AutoCAD 2011 LT version and I am not able to open AutoCAD from Excel.
The same is working well if used with AutoCAD 15
Is this a limitation with LT version?
Solved by steven-g. Go to Solution.
Most of the programming languages that are available in full Autocad are disabled in LT, if this is something that you did previously in full Autocad then I doubt it will work, if however you have run this previously in LT I would be fascinated to see the full program that you use in EXCEL.
You are right just realised I had the full 2018 version. Darn it back to the drawing board!
