AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
NON RIESCO A STAMPARE PDF CON MISURE PERSONALIZZATE - I CAN'T PRINT PDF WITH CUSTOM SIZES
9 REPLIES 9
Message 1 of 10
studio_merciai
1441 Views, 9 Replies
Buongiorno, con la nuova versione autocadlt 2024 non riesco ad effettuare la stampa in pdf con misure personalizzate. In pratica prima con versioni precedenti lanciavo la stampa o con pdfcreator o con pdfxchange e quando lanciavo la stampa selezionavo la stampante virtuale quindi proprietà e personalizzavo la stampa con lunghezza a piacere ed altezza formato massimo del mio plotter (610), mi creava il formato personalizzato e stampava correttamente. Ora con la nuova versione di autocad lt 2024 non riesco più ad effettuare stampe pdf con misure personalizzate ma solo formati A4 - A3- A2 -A1 -A0. Qualcuno ha lo stesso problema ed in caso affermativo come ha risolto?
grazie
[Translated by Google 9/12/24]
Good morning, with the new version of autocadlt 2024 I can't print in pdf with custom sizes. In practice, before with previous versions I launched the print or with pdfcreator or with pdfxchange and when I launched the print I selected the virtual printer then properties and customized the print with the desired length and maximum format height of my plotter (610), it created the custom format and printed correctly. Now with the new version of autocad lt 2024 I can no longer print pdf with custom sizes but only A4 - A3- A2 -A1 -A0 formats. Does anyone have the same problem and if so how did you solve it?
thanks
9 REPLIES 9
Message 2 of 10
paullimapa
in reply to: studio_merciai
Have you tried using AutoCAD 2024 LT's built-in dpf pc3 to create pdfs like DWG To PDF.pc3?
Works for me when I create a user 8.5x14 paper size with following steps:
In Plot window under Printer/plotter select DWG To PC3.pc3
Click Properties
Under Device and Document Settings click Custom Paper Sizes
Click Add and then create your custom paper size
Lastly save the setting over the current DWG To PDF.pc3
Now under Paper size click on drop down and at the very bottom is the added User paper size:
Paul Li
IT Specialist
@The Office
Message 3 of 10
pendean
Message 4 of 10
Ciao @studio_merciai
Grazie mille per aver postato la tua domanda nel forum! La soluzione suggerita da @pendean @paullimapa ha risolto il tuo problema?
Non vediamo l'ora di ricevere ulteriori informazioni in modo da poterti aiutare come comunità!
Hi @studio_merciai
Thanks so much for posting your question in the forum! Did the solution suggested by @pendean @paullimapa solve your problem?
We look forward to hearing more so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Message 5 of 10
Buongiorno anche , con la nuova versione autocadlt 2024 non riesco ad effettuare la stampa in pdf con misure personalizzate con le stampanti virtuali. In pratica prima con versioni precedenti lanciavo la stampa o con pdfcreator o con pdfxchange e quando lanciavo la stampa selezionavo la stampante virtuale quindi proprietà e personalizzavo la stampa con lunghezza e altezza , mi creava il formato personalizzato e stampava correttamente. Ora con la nuova versione di autocad lt 2024 non riesco più ad effettuare stampe pdf con misure personalizzate ma solo formati standard.
Ho letto le risposte ma non è quello che vorrei (così sono in grado anche io di stampare con formato personalizzato), mi piacerebbe che qualcuno mi indicasse la soluzione per poter utilizzare pdfcreator come prima, è estremamente più comodo e inoltre le stampe risultano come pdf puliti, senza menu laterali.
Grazie!
grazie
Good morning also, with the new version autocadlt 2024 I can't print in pdf with custom measurements with virtual printers. In practice before with previous versions I launched the print or with pdfcreator or with pdfxchange and when I launched the print I selected the virtual printer then properties and customized the print with length and height, it created the custom format and printed correctly. Now with the new version of autocad lt 2024 I can no longer print pdf with custom measurements but only standard formats.
I read the answers but it's not what I would like (so I can also print with custom format), I would like someone to tell me the solution to be able to use pdfcreator as before, it is much more convenient and also the prints are as clean pdfs, without side menus.
Thanks!
Does anyone have the same problem and if so how did they solve it?
thanks
Message 6 of 10
Ho esattamente il suo stesso problema. Diventato tutto piu' macchinoso essendo costretti a utilizzare dwg to pdf
I have exactly the same problem. It has become more cumbersome being forced to use dwg to pdf
Message 7 of 10
Pare non cia sia altra possibilità. Peggiorativo!!!
It seems there is no other option. Worsening!!!
Message 8 of 10
Anche io ho lo stesso problema, dapprima con Autocad LT 2024, ora anche con il 2025.
I too have the same problem, first with Autocad LT 2024, now also with 2025.
Message 9 of 10
f.poletti
Good morning, are there any updates from the development team?
Message 10 of 10
paullimapa
in reply to: f.poletti
We’re all users here just like you. You should contact Autodesk directly and open a troubleshoot ticket
Paul Li
IT Specialist
@The Office
Technology Administrators
