AutoCAD LT Forum
No menus in AutoCAD LT 2014 running on Windows 8 - how can I get this resolved?
57 REPLIES 57
Message 22 of 58
2026 Views, 57 Replies
The menus that were along the top of the LT window since I first installed the product years ago have now disappeared, rendering the product unusable. I need to get back to where I was on Monday or else my software is nothing more than an expensive space holder in my system.
I uninstalled LT and reinstalled it - no change.
So far - no response - is there another source of help at Autodesk? This is the first problem I have encountered that required support but it has stopped production and I really need to get an answer.
So - two questions - how do I get AutoCAD LT 2014 back to its original state, and if there is no answer for that, where else can I go to get some help on this issue. It is getting to be very frustrating and I need to get back to work.
57 REPLIES 57
Message 1 of 58
I am losing days of work that I can ill afford due to disappearing menus and no clear path to getting them back. I am getting desperate here - is there any source of help that would at least give me a starting point towards regaining the ability to use this software?
Message 2 of 58
Binga
Try resetting your Ribbon:
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Message 3 of 58
in reply to: Binga
I have attempted to do that with no luck - specific, step by step instructions are required - the CUI interface keeps saying my menu(x) is empty and won't be displayed. This is frustrating in the extreme.
Message 4 of 58
Binga
Could you share some images showing the error?
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Message 5 of 58
in reply to: Binga
I don't know how to do that. Imagine AutoCAD LT with no menus and that's pretty much it. I can get the Classic AutoCAD menus to load, but they are useless. I want the ones that were there when I first installed AutoCAD LT 2014.
Message 6 of 58
in reply to: Binga
I can't find the reset ribbon command.
Message 7 of 58
Binga
Is your ribbon like that?
You can press the arrow in the upper right corner (marked)!
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Message 8 of 58
Binga
in reply to: Binga
Sorry. You are using AutoCAD LT??
Try to put your question in the designated Forum: http://forums.autodesk.com/t5/autocad-lt/ct-p/2000
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Message 9 of 58
in reply to: Binga
No, I have AutoCAD LT 2014.
Message 10 of 58
My AutoCAD LT 2014 menus disappeared and I can't get them back. I need at least a starting point to try and recover where I was yesterday - I am losing too much time trying to sort this out with no positive results.
Message 11 of 58
Binga
If you ask in that place, many experts will help you! I don't know much about AutoCAD. And this forum is for others subjects (actually Meet and Greet).
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Message 12 of 58
My menus disappeared and I can't get them back. How can I restore AutoCAD LT 2014 to its original format?
Message 13 of 58
sthompson1021
Click on the start button on your desktop, go to all programs, autodesk, autocad LT2014, select reset settings to default.
Message 14 of 58
in reply to: sthompson1021
There is no "start" button - I am running Windows 8 and I can't find a button that allows me to access all programs.
Message 15 of 58
sthompson1021
Sorry, I haven't used win8 so you'll have to wait for someone else to chime in
Message 16 of 58
Emmsleys
Have you tried logging in as a seperate user to see if the issue occurs in that brand new profile on your system?
Do you still have the issue if you reset your settings to default?
Sarah Emmsley
Technical Support Specialist
Message 17 of 58
Emmsleys
Also you can refer to the following AKN article for additional support if it applies.
Tabs or panels are missing from the ribbon in AutoCAD
Sarah Emmsley
Message 18 of 58
in reply to: Emmsleys
I uninstalled AutoCAD LT 2014 and reinstalled it. There are still no menus. There is a ribbon menu on the side of the screen, if I click on that, I get a few menus, such as the draw menu, which I can then drag off the ribbon and drop it elsewhere, it just sits there on top of items below it - it is not integrated with anything. I can drag the command bar up and drop it at the top of the drawing window, so that's good, but I am used to having a number of menus across the top of the screen - draw, modify, measure and so on. Even if I manage, laboriously, to recreate the work environment I had yesterday, I am concerned that it will evaporate again. And I don't see any way of integrating those disparate menus into one larger menu.
Message 19 of 58
Are there any tutorials on how to create or load menus for AutoCAD LT 2014? Nothing is working, and my design work is dead in the water. Surely there must be someone out there with a suggestion.
Technology Administrators
