Morning,
The attached has been sent to me, I'm aware it is asking for Xrefs but non have been supplied, so I'm taking it that's why I see no drawing?
Although in the viewing tab when I select the dwg on my desktop I see a full drawing?
Mark
Solved by h_s_walker. Go to Solution.
Solved by steven-g. Go to Solution.
Without even opening that drawing I can see it's too small. 145kb isn't enough to even hold a gnat's fart
Ask whoever sent you the drawing to use ETRANSMIT. This will ensure that all elements needed to view the drawing properly will be put into a zip file, which they can then send
Howard Walker
