Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was wondering if there is a function in Autocad LT that take cares of automatic numbering of attributes from blocks.
For example, i need to number 300 lamps (F1,F2,F3...).
So i need someting that can name them sequently without individually change the attributes block by block.
I know you can give your blocks the same attribute name using properties but can i do the same but sequently ?
thanks
