My layout moves after plot
annelies.roelofs
Observer
Observer
annelies.roelofs
Observer
Observer
Hi knowledge centre!
I sometimes work in AutoCAD LT with some light editing I learned from a colleague. So I am not a trained AutoCad professional. I was annoyed by the number of pop ups I get when I want to plot, so I started looking at settings, see if I could remove this irritation. I changed the plotter settings a couple of times but it not make things better.
In stead, now, after I plot the layout (plot looks fine) when I return to my layout, the frame (everything) has moved a bit to the right and up.. of course I can use undo and change it back before saving/leaving. But I really need this fixed. Can somebody explain how in a 'AutoCAD for dummies' matter?
Annelies
pendean
Community Legend
Community Legend
Did you click the APPLY TO LAYOUT button on the PLOT command pop-up? That's about the only way to easily do what you show in your screenshot.
Or you had a badly defined PAGESETUP that got fixed after plotting.
