Multiple Attribute definitions in a block
janu319
janu319
Hallo everyone,
I created a block with 4 variable attribute definistions as shown in the attached screen shot, but when I change the text values in one attribute definition, the other attribute definitions are not moving accordingly. So there is a overlap of texts, I tried to add move parameter but no use.
Can some please help to fix this.
Thanks in advance,
Janu
pendean
Community Legend
Community Legend
So these are 4 floating separate attributes? If yes, how would the program know how to move them? These would be the same as line of circles sitting side by side and you change the size of one circle for example.
They either needs to be ONE attribute (you know, one single line of text), or each attribute needs to be on it's own line (stacked vertically), or you need to manually move the other attributes with grip-editing after the fact.
I'm not sure if it can be done as a dynamic block but the folks in that forum can confirm too https://forums.autodesk.com/t5/dynamic-blocks/bd-p/154
