- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have mtext that I want to convert to plain text so that the alignment doesn't shift when some capital letters are slightly above or below others in some fonts. Unfortunately I didn't realize that mtext does this shift until I had a couple of thousand drawings where the exact alignment of the letters is vital. I found the TXT2MTXT command, but I am looking for the reverse. I tried MTXT2TXT, but the command line autocorrected to TXT2MTXT.
I am using AutoCAD LT 2024 on Windows 11, but have access to full AutoCAD and C3D if there is something in them I can use, or a lisp routine.
Brad
LT, C3D 2005 - 2026
Windows XP, Vista, 7, 10, 11
LT, C3D 2005 - 2026
