I have a monthly reccurring subscription for AutoCad LT. Currently it is installed on my desktop at work. I would like to have access on my laptop as well. As I am only one person, only one location would ever be in use at any given time. Is this even possible, or do I need a whole new licesnse?
Solved by DarrenP. Go to Solution.
Solved by pendean. Go to Solution.
Solved by john.vellek. Go to Solution.
Hi Dan,
Welcome to the forums!
Here is a link that describes the Subscription model. Take a look at the Home Use Rights.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
you can install and run up to 3 machines for the same user
read section 2.4.4
DarrenP
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
