Moving 2011 LT to a different computer
Message 1 of 17
My works computer is due for a change and I have to transfer 2011 LT across.
I know I have to obtain a new activation code but I don't have the original installation disc to load.
Can this be done without the disc or is  an upgrade required?
Thank you kindly.
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
Read this about Windows 10 if thta is what is going to be on your new PC  http://autode.sk/1IY4C2X
Older software like LT2011 are not available as downloads from Autodesk: But the Autodesk Customer Care team may (or may not) be able to help you get the link/info you need. Please contact the team by clicking here https://knowledge.autodesk.com/contactus/downloads-upgrades/finding-download?_ga=1.181347812.2126739...
Message 3 of 17
Emmsleys
If you run into an issue with contacting our Customer Care team post back in this thread. I'd be happy to help.
Thanks.
Sarah Emmsley
Technical Support Specialist
Message 4 of 17
Sarah,
I have LT2011 on a old (W7 64B) computer and need to transfer my settings to my new computer (W7 64B) with LT2015 on it.  How do I do this?
Message 5 of 17
pendean
Community Legend
Community Legend
There is no automated ability to do that: what "settings" are these that you want from the old version on the old PC?
Message 6 of 17
Thanks for responding.
I would like to transfer my custom settings such as toolbars.
​John​
Message 7 of 17
Emmsleys
Have you run the AutoCAD LT 2015 trial already?
This could be an option for you to test.
  • Install the newer version of AutoCAD in trial mode on the old system. Use the Virtual Agent
  • Migrate settings to that version as you install.
  • On the Start menu, use the Export [product_name] Settings option under the Migrate Custom Utilities menu to export those settings.
  • Copy the resulting ZIP file to the new computer.
  • Import the settings using the Import [product_name] Settings option under the Migrate Custom Utilities menu.
Let me know if that works. I'm sure others will be posting there suggestions here shortly.
Sarah Emmsley
Message 8 of 17
I uninstalled LT2015 yesterday on the old computer. I tried installing
(using my CD) it again in trial mode on the old computer and there was an
error. Autodesk Desktop App did show up on desktop.
Message 9 of 17
Emmsleys
Not a problem.
Just to make sure, did you get what you needed? I was a bit confused by the post.
Let me know if you have any questions.
Thanks.
Sarah Emmsley
Message 10 of 17
No, I cannot reinstall 2015 (trial) on my old computer to migrate settings
from 2011 to 2015. Any ideas?
Message 11 of 17
Emmsleys
Can you export your settings from 2011 and post them here? I can see if I can import them on my end to help you out.
Sarah Emmsley
Message 12 of 17
pendean
Community Legend
Community Legend
Toolbars are stored in tjhe CUI file in LT2011. Go find it, grab it, put on a thumbdrive, open CUI command in LT2015, hit the transfer tab, find the tumbdrive file, drag and drop between there and 2015's menu.
What else needs to move over?
OR... you need to install 2011 on the new PC then, export 2011's settings from the old PC to a zip file, hope all is captured, put on a thumbdrive, transfer on the new PC, start 2011, import those settings. when all if working well, start LT2015 and "migrate".
PS: are you sure recreating the toolbars you need in LT2015 would not be simpler and quicker?
Message 13 of 17
​See attachment​
Message 14 of 17
​See attachment​
Message 15 of 17
I searched for a .CUI file and found many .CUIX files. Any idea which one
I need?
​JW
Message 16 of 17
pendean
Community Legend
Community Legend
OPTIONS command in LT2011
FILES tab
Expand the CUSTOMIZATION FILES section
Expand MAIN CUSTOMIZATION FILE section
There is full path to the CUI file your LT2011 session is using.
Message 17 of 17
​It's working! Thanks for all your help.​
