Monochrome paperspace viewport is pixelated - need high resolution
Zgurkogel
Message 1 of 30
Zgurkogel
Dear fellow AutoCAD users,
At work we use screenshots for production task lists. These screenshots require black objects on a white background. To do this, our drawings feature a monochrome paperspace tab. (model space is run with a black background) Screenshots are made using "greenshot", a screen capturing software. The outcome is rather pixelated, making images useless. See settings and screenshot below.
The workaround is to switch modelspace to a white background, make a screenshot and revert back to a black background. Having to do this 20 times a day is just plain cumbersome.
Long question short: how can we generate high resolution screenshots of a monochome paper space tab? Looking forward to reading useful suggestions. Thanks!
https://imgur.com/KkG5BlS
https://imgur.com/hNiBpMj
Replies (29)
Message 21 of 30
paullimapa
2022.1.5 is the latest version you should be using so you should at least update to that version which may make it possible for you to run the Gfxdx12 command.
Paul Li
IT Specialist
@The Office
Message 22 of 30
Zgurkogel
Just upgraded to 2022.1.5 and the Gfxdx12 command is not present. Could it be I need to install an extra package (like for example Express Tools) to get this command to work?
Message 23 of 30
RSomppi
It should be there with the base install.
Message 24 of 30
Zgurkogel
EDIT: I expected the command to work by just typing GFX. Well that didn't work as there is no shortcut. Typing the full command made it work. Sweet. Now back to getting the paperspace monochrome resolution issue sorted. 🙂
Message 25 of 30
paullimapa
Finally. Ok after setting Gfxdx12 to 0 and did you exit and restart AutoCAD?
Now enter command GraphicsConfig, do a screenshot and share that here.
Paul Li
IT Specialist
@The Office
Message 26 of 30
Zgurkogel
Here you go - this was after restarting AutoCAD.
Again a screenshot of the full AutoCAD screen and the monochrome paperspace tab (see below). No different than before so still too low a resolution. 😞
* EDIT * running the highest possible resolution, which is 1920x1028.
Message 27 of 30
paullimapa
This is very strange because after setting Gfxdx12 to 0 and exit and restart AutoCAD the GraphicsConfig window in the upper right hand corner next to Virtual Device  should no longer show Directx12 but Directx11
As an alternative to your screen capturing tool have you tried Windows builtin Snipping Tool?
Paul Li
IT Specialist
@The Office
Message 28 of 30
pendean
Community Legend
Community Legend
@Zgurkogel Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Do so now.
Message 29 of 30
Brock_Olly
Maybe it's your pdf quality/DPI settings?
Check if these are high enough
Message 30 of 30
Zgurkogel
Settings look fine to me. It's the screen resolution that seems messed up. Whatever I try, the monochrome paperspace viewport resembles an ancient VGA monitor. Going with @pendean's advice and contact support. Haven't got round to doing that yet.
