Model dissapears
Model dissapears
rpreston513
Message 1 of 10
Model dissapears
rpreston513
I'm using AutoCAD LT 2021. I'm editing a drawing created by someone else. Both the model and layout are in MSPACE. When I select anything (or everything) in the layout and convert it to PSPACE anything that was selected disappears from the model. Scaling doesn't seem to help. Zoom-Extents doesn't help. What am I missing?
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
can you share your DWG file here with us?
Message 3 of 10
rpreston513
Sure. I'll try.
Message 4 of 10
pendean
Community Legend
Community Legend
Thanks for the file: I see a diagram and titleblock in modelspace, and in paperspace I see an unlocked viewport looking at the that content with the cursor inside the viewport. There is nothing else in paperspace other than that viewport.
All of this is normal: so what exactly is the issue, do you knot know how to exit a viewport in paperspace?
Do you wish to not use paperspace? Are you trying to resize the viewport?
Are you very new to the concept of paperspace? or AutoCAD in general?
Please elaborate so we can best help you based on your experience level.
TIA
Message 5 of 10
steven-g
Are you using the chspace command, because that is what it does it moves everything you select from modelspace into paperspace.
Message 6 of 10
rpreston513
I am definitely an amateur. I do a lot of copy/paste. I recognize terms like pspace, mspace, viewport but i don’t have a solid understanding of them. No i don’t know hoe to exit or resize a viewport.
Message 7 of 10
cadffm
open your file (the attached one),
click to Layout tab [HP9800], click the [MODEL] button in your statusbar below
SAVE the file
open YOUTUBE
search for
AutoCAD Model and Layout
In short:
In model tab is your model
Layouts are like papers, you can add Viewports to the layout, it's like cutting a hole to see the model content
So, you saw/see in Model tab and in Layout tab the same objects, the objects from the model  tab 🙂
Sebastian
Message 8 of 10
steven-g
No worries, you said in the first post that everything disappears when you convert it to PSPACE
What command or method are you using to 'convert' the objects?
Message 9 of 10
pendean
Community Legend
Community Legend
got it: consider helping yourself to online tutorials as noted by others, this is not a program you just dive into, start messing with model/paper space and hope it all works out in the end.
To exit a viewport, move your cursor away from it then double-click. Or type PSPACE then hit <enter>. There is no need to resize it, whomever created it did it correctly and it is ready to use as is. If you are trying to change scale of the viewport (and thereby also messing with the modelspace titleblock size) you can read about how to do that here from HELP inside your program https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC...
Message 10 of 10
rpreston513
Thanks to all who replied. I'll definitely watch the videos to develop a better understanding of viewports.
