AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
MIRRTEXT Resetting
1 REPLY 1
287 Views, 1 Reply
MIRRTEXT Resetting
MIRRTEXT will reset when I open drawings on my companies server. I can set it to 0, save and that drawing will open with a 0 but others in the directory open with a 1. If this is a system variable, why do certain drawings reset it? I know it resets because the system variable changed bubble pops up every time.
I am running AutoCAD LT 2021 R119.0.0
MIRRTEXT Resetting
1 REPLY 1
cadffm
cadffm
There is no 'reset', because...
Start
command: Mirrtext<enter>[F1]
Read more about that function you are using.
and you can see:
Saved in: Drawing
So it is a setting inside a dwg/dxf/dwt file, like blocks, Layers and so on too.
Sebastian
Start
and you can see:
Saved in: Drawing
Sebastian
Technology Administrators
