Hi, The mirror command is not working as I would expect it to.
It is clunky and requires me to type in N
Even though the default is <No>
Where in the configuration file do I find this?
And can it be set so there is no additional keystroke required?
Further to this is.
Would upgrading to the to the full Autocad version provide increased productivity when using the basic commands?
Solved by hwalker. Go to Solution.
It does not require you to type NO since the default is NO all you have to do is press ENTER
Howard Walker
In AutoCAD, when you see words inside <> that means the default is ready for you to use without doing anything extra at all. It is common in many commands in AutoCAD, now you know.
