mbuttonpan
mbuttonpan
mbuttonpan
I somehow lost the pan function on the mouse wheel button.    I have confirmed that the variable is set to 1.    I have also confirmed that the pan function works on another computer running AutoCAD LT with this same mouse.
pendean
Community Legend
Community Legend
You mouse driver for the middle button is what?
Your mouse driver make/version is what?
Emmsleys
Are you able to test another mouse?
Were there any new updates that can be applied to your mouse?
Sarah Emmsley
Technical Support Specialist
Thank you for your reply. The mouse in question had been working fine since
I installed AutoCAD LT on this computer last year & only stopped working a
week ago. Before emailing you & after reinstalling a freshly downloaded
mouse driver I checked the MBUTTONPAN parameters. I then plugged this
same mouse into another computer running AutoCAD LT & the pan function
worked properly so I assumed that I was having a software problem. Last
night I tried a different mouse on this computer & the pan function works
fine. I don't understand how this can be, but it's working.
Phil Neis
