Macro to open file location folder
dewie125
dewie125
Hi Guys.
I currently have Autocad LT 2018
I am trying to use a macro to open up my file location in explorer. I have seen a few Macro's using "START" or "STARTAPP", but my LT version doesn't support it.
I use "AI_startapp".
This is how far i came:
^C^C_AI_startapp;explorer.exe; $M=$(SUBSTR,$(getvar,Dwgprefix),1);
The problem i am facing is that Explorer opens up in "Quick Access". I then have to close it and hit enter in cad again and this will open up the correct folder, but it leaves my location breakdown in my command bar. Please see my attached file.
You will find my location of my file below, but keep in mind this location should change. This is why i am using Dwgprefix.
Y:\Clients\Active\Cameron ....\141 ....\Drawings\CAD\Sketch Plan\ERF ....
Much appreciated.
pendean
Community Legend
Community Legend
Turn off QUICK ACCESS in Windows 10's File Explorer, nothing you can do about it with LT https://www.windowscentral.com/how-remove-quick-access-file-explorer-windows-10
dewie125
Thanks for your prompt response Dean.
Is there any way i can export the dwgprefix to a text file or any other file?
I would then start a cmd app, which reads the dwgprefix and open its destination.
I am quite new to Macro, but this would make my life a lot easier.
Thanks.
steven-g
Would having an attributed block work, the attribute using a field to read the dwgprefix, and then a macro to run attext which gives a txt file output, which you can place in a named location for your cmd file to read
dewie125
Hi Steven
This is great! I understand the thought process. This is excellent!
The last thing i am currenlty struggling with is the template file.
I keep on getting invalid field specification. I have never used ATTEXT.
I have created a attribute named: Test
I then added the the field into the value of the block.
I used file path. (It displays perfectly in Model space)
The problem i am facing is when doing the ATTEXT command.
My current template file is set up like this:
BL:NAME CWWW000
Yet Autocad Give me the following:
Command: ATTEXT
** Invalid field specification:
BL:NAME CWWW000
I Have tried multiple options.
BL:NAME CWWW000
BL:NAME C0080000
BL:NAME C016000
dewie125
Hi Guys.
I figured it out. I had so blank spaces or lines within my template file, which i had to remove.
Everything is running smoothly.
Thanks guys for your assists on this topic.
I will mark this as solved.
steven-g
Great glad to hear you have it working.
