Message 1 of 9
- Mute
- Permalink
- Report
I'm trying to make a custom button, but can't seem to select a previous object.
What I'd like to do is use chprop to change a selected text color to 2 (yellow) then edit the text. Doing it in the reverse order would also be fine, just as long as the button lets you select text, lets you edit the text and makes it yellow.
Any help would be appreciated. Also, does anyone know how to assign a macro to a key combo or command? Lisp isn't an option as this is AutoCAD LT.
