When doing architectural drawing vs general drafting, using AutoCAD Architecture is a huge step up in productivity, similar to the productivity increases when using Revit. ACA has wall, door, window, stair, roof, roofslab, slab, railing, curtainwall, ceiling, column, furniture, appliances, plumbing fixtures, and other AEC model objects that have the ability to display themselves in different ways (plan, elevation, model, section). Material hatch, scheduling, annotation, dimensioning, and annotation are automated or semiautomated. Rendering is facilitated. Sheet set management, including placing views on sheets is also more easily managed. Downside is that both ACA and Revit require significant efforts to learn and to master. Modifying object styles can be challenging. But the program can result in an immediate productivity boost even if you only use the plan generation features and detailing features.
It's a bit long but this video might be of help: https://www.youtube.com/watch?v=RQX_A9aOg4A
Also, if you're on AutoCAD subscription, all the toolsets are available to use.
Architect, Registered NC, VA, SC, & GA.
