Hi Smarter-people-than-me,
What happened to the Dim command in 2017? I'm totally frustrated by this.
It may have happened in 2016...I went from 2015 to 17 so forgive me if this is adressed somewhere but I couln't find it by searching.
I know how to get to the DIM command. I want a horizontal dimenion across two things that are not aligned vertically. I don't want vertrical extension lines the full depth of the dimension. I want a little point at a wall on one end and an extension line at the other but if I try to do that now I get an "aligned" dimension at an angle. Virtually useless. If I pull a horizontal dimension using dim linear I get extension lines across the drawing.
I used to type D (get Dim) and type HOR for horizontal. Now, even if I get the "dim" command (not dimlinear), it doesn't recognize HOR and VER. I'm not stuck in the past so much that I can't advance but I don't know how to achieve what I could previously do with the new version.
A) is it possible to do like the old D - HOR technique and
B) if so, how?
Please help! And, thanks!
