Link Data Table to OpenOffice Instead of Excell?
greevedogg
greevedogg
Just as the title says, is there a possible workaround for linking a data table with OpenOffice instead of MS Excell?
pendean
Community Legend
Community Legend
Open Office Org Calc files are not supported as far as I can tell: Is the file extension still XLS and you've tested it already?
greevedogg
No, not yet necessarily...
I tried to create a data link first by using the data link manager, but because I don't have Excell Installed, it doesn't get past that stage. I can saveas .xls or .xlsx in OpenOffice Calc, I do believe, but not sure how to link data if I had a table created in OO.
Ultimately, I am just trying to create a simple table across multiple page in my sheetset, and be able to update them as new info becomes known. Basically, just a LABEL MATERIAL DESCRIPTION table in our shop drawings.
The cut-and-dirty way I have been doing it, is just copying the table and data in the tool palette, and deleting the old incomplete table and re-inserting the updated table each time.  It's not too overly time consuming, but there's got to be a better way...
pendean
Community Legend
Community Legend
AFAIK you need MSExcel for the linking task with LT as an OOTB function unless you can test and confirm otherwise (we don't use OO here).
steven-g
I can't speak for Open Office, but I just ran a test with WPS Spreadsheets. saved a file with the .xls extension. And Autocad created a link without problem to that file, I updated the contents in WPS saved it, and Autocad updated to the new values. So it looks as though it only needs a file with the .xls extension to work
greevedogg
Thanks @steven-g for testing. May I ask, how did do create the link within AutoCAD to the xls file?
Edit: I just D/L'ed WPS Office Free, and was able to create a spreadsheet in it and link it to AutoCAD. So, this will work for me! I don't mind ditching OpenOffice for WPS for this added functionality!
Awesome!
ppako
Reporting on WPS Office - it's current version (12.2.0.13359) doesn't work with acad MEP 2020, 2021, 2022, and 2023. Just waisted an hour testing it.
