Announcements
Linetype merge
abi.saunders
Linetype merge
abi.saunders
Instead of purging a linetype, is there a merge linetype in LT? I have lots of linetypes imported from another drawing but they are probably in use in various blocks etc that would take ages to go through. The merge layers command is a very quick, easy way to get rid of layers and it would be great if this existed for linetypes!
cadffm
>>" a merge linetype in LT? "
No
you need a way to do it outside of LT.
Another program or as Ascii DXF+TextEditor(+the knowledge to do that)
Sebastian
pendean
Community Legend
Community Legend
You will need Full AutoCAD's CHECKSTANDARDS command can do it with a clearly defined DWS standards template file, if you have access to both of course.
