Archstyl font not displaying fractions, etc
Message 1 of 13
Bought a new computer and installed archstyl.shx font on it.  When I open a drawing, the special keys don't show their assigned values: for example the "\" key doesn't display as "1/2" like it used to.  Any ideas?
Replies (12)
Message 2 of 13
RobDraw
Did you put it in the same folder as the rest of your .shx fonts?
Rob
Message 3 of 13
Yes, same folder.  All of the letters and numbers appear correctly, but none of the fractions, or diameter symbol, or plate symbol appear as they did last week - on the previous computer.  They are just represented by the marks on the keys.
Message 4 of 13
steven-g
How did you 'assign' the keys before? Otherwise what you see on the keyboard is what you get. Or do you mean something else?
Message 5 of 13
RobDraw
Maybe you need the .ttf version?
Rob
Message 6 of 13
pendean
Community Legend
Community Legend
That very old 1986 custom SHX font have unique codes for fractions, are you using the correct ones? Doesn't appear to be so
Message 7 of 13
Steven-
I've never had to assign the keys before - I guess that's where I need to start(?)
(In the past 21 years, I've had to get a new computer maybe 4 times.  I just installed the font, and everything would work fine - except this time.)
Message 8 of 13
Rob-
I can't find a ttf version online - any locations that you know of?
Message 9 of 13
This is a list of some of the key assignments that I've used since probably '95 with archstyl:
\ = 1/2
> = diameter
[ = 3/4
] = 7/8
| = 1/4
{ = 3/8
} = 5/8
_ = 1/8
Message 10 of 13
pendean
Community Legend
Community Legend
Are you sure your font is loaded? Find out, there should be not yellow exclamation tag (or "missing" tab) on it in STYLE command.
Otherwise I suspect there is something else that needs to be in place/at play/turned on/button pressed perhaps for you to be able to do that with this SHX font. Sorry, I have it and testing in AutoCADLT 2018-19-20-21 your shortcuts do not give me those fractions.
Message 11 of 13
steven-g
It works here in LT 2021, the shx file is located at
C:\Users\username\AppData\Roaming\Autodesk\AutoCAD LT 2021\R27\enu\Support
Most work I get the fractions just fine, the one that doesn't work is > = diameter (I get PL property line?)
Message 12 of 13
I put the font in that location, restarted the computer, and still not working.
(You are correct: ">" symbol is for PL, which stands for "plate". )
Message 13 of 13
I removed the archstyl font, then found a new one online, re-installed it at the location Steven gave - now all works fine.
Thanks everyone for the help.
