Hi
I am using AutoCAD 2019LT
I am looking at drawing up a site drainage plan and to my surprise there are no surface / foul waste linetypes and they have to be custom made. So I created the code in notepad and now I cant find the autocad folder where all the linetypes reside. I am starting to think it is not possible in LT version, am I correct? Also it is not clear if the notepad txt file should retain its.txt extension or if this should be renamed to .ln?
I have never created a custom linetype before and all info on the web including Autodesks help & nothing answers the above questions.
Solved by cadffm. Go to Solution.
1. The extension is ".lin"
2. You can load linetype from whereever you want
command LINETYPE
Standard *.lin are stored in
"C:\\Users\\<user>\\appdata\\roaming\\autodesk\\<autocad version>\<release>\\<language>\\support\\
Sebastian
Thanks Betreff
I can see the location through AutoCAD's LINTYPE command by clicking the File... in the Load Reload Linetypes Dialog box and it is exactly how you explained but if I go through windows explorer the App Data folder is missing.
Sebastian
