Linear dims with leader
lee.pellegrin
Message 1 of 8
lee.pellegrin
I would like to know if there is a wat to trigger a dim leader to go to the left or right? All of my dims are going to the right  when I home the text.
Replies (7)
Message 2 of 8
h_s_walker
Edit the multileader style. See the image below
Howard Walker
Left Handed and Proud
Message 3 of 8
lee.pellegrin
Is the dim style and mleader style connected somehow?
Message 4 of 8
pendean
Community Legend
Community Legend
No, not at all. the less capable LEADER and QLEADER commands have more in common with your active DIMSTYLE setting, but there is no "automatic" dimtext with leader placement left or right, or up or down, in any of those commands.
Message 5 of 8
lee.pellegrin
I'd like to know if I could change anything on the properties panel in order to change the direction?
Message 6 of 8
h_s_walker
Try below
Howard Walker
Message 7 of 8
lee.pellegrin
These are my options.
Message 8 of 8
pendean
Community Legend
Community Legend
@h_s_walker has an MLEADER selected and showing you want you can do only with that object type, you have a dimension selected so the choices are much less and not the same.
Sadly, not with any dimension text.
