I have created a CAD drawing. I have no issues with line weights on multiple layers in layout model space. I performed the "from template" command to insert a title block into paper space. I select object of the title block, rt click properties, select color by block, layer is my proposed structure, linetype by layer, line weight 1.4mm. Paper is Arch D.
I used the layers by viewport to define my PDF print. Worked as designed. Why can't I get the title block line weight alter in thickness?
Solved by steven-g. Go to Solution.
Solved by pendean. Go to Solution.
I am in paperspace. not in the layout viewport. I select the perimeter line, rt click to properties. It defaults to block & I adjust the line width. I routinely drew the title block in model & saved as a template. Brought the template into paper space.
