AutoCAD LT Forum
Line Tool Not Properly Functioning
2 REPLIES 2
1211 Views, 2 Replies
I am having a difficult time getting the line tool to properly function all of a sudden. It was working perfectly fine; I did not change any settings; all current settings are the same as the settings on my other computer...but when I opened it last the line tool was being all weird. When I draw a base line and then hover over a snap point to determine where I want my origin point of my next line to be I typically hover left or right, type in the distance I want the new line to start from the snap point, hit enter and then the new line starts at that point. NOW whenever I try and do this, the new line starts way off from where it should be starting...Like I said, I have not changed any settings. Has anyone had this issue? I hope the photos help. CAD Screenshot 01.PNGCAD Screenshot 02.PNGCAD Screenshot 03.PNGCAD Screenshot 04.PNGCAD Screenshot 05.PNG
2 REPLIES 2
pendean
Turn off any running osnaps, manually type the snap you want only when you want it, and see if the problem goes away.
Emmsleys
Following up on your thread, were you able to try the suggestions made?
Sarah Emmsley
Technical Support Specialist
Technology Administrators
