I was adding a leader and it is not working properly. I’ll do my best to explain. The ortho setting doesn’t matter, it will only go up and down, also the text shows up as a dashed line and none of the dimension commands will work. Has anyone had this happen before? I’m in AutoCAD LT2023.
Solved by steven-g. Go to Solution.
