LAYOFF (Command) confused
Message 1 of 8
aaronB27K2_0-1612397935613.pngThe Layer off command is a useful tool to quickly clear away unwanted layers. I use it every time  I open a drawing to quickly clear away layers I'm not working.  The problem I'm having is layers, that previously turned off just fine, no longer turn off but stay visible.  The command bar reads "Layer 0 has been turned off" as if the object selected was on layer 0, when it is not and nothing happens.  This can be verified by selecting the same object and seeing the layer the object identifies with.  The LAYOFF feature worked before with the same file and same layer but at some point just stops. I'm having the same issue with multiple files and multiple layers.  It seams to work a few time for a layer then stops working. Any solutions to this problem. Running AutoCad Lt 2021, Windows 10.
Replies (7)
Message 2 of 8
steven-g
Is the object you select a block? A block might be on layer "0" but if it contains objects that are on another layer they won't turn off. Can you post a .dwg and point out some of these objects that don't turn off?
Message 3 of 8
pendean
Community Legend
Community Legend
make a copy of the block, explode the copy, now find out what layers the objects in the block are on. Does that answer your question about layer 0 being affected?
I also suspect you probably ought to switch to LAYFRZ and LAYTHW, the freeze/thaw layer options avoid the issue you report, plus they have the added benefit of making those layers unselectable as well if you never new that before.
Message 4 of 8
Goran_Kingkong
I also got this problem. LAYFRZ and LAYOFF says "Layer "0" has been frozen." even tho the selected object is not on layer 0. so it remains on..
Message 5 of 8
cadffm
I'm pretty sure AutoCAD knows better than you do 😁
or your version is buggy. [what is your Productversion, command: ABOUT and share your sample object: as DWG file]
Has this ever happened to you with a circle or a line? I do not think so.
Apparently you have a block-reference and the objects in the block are on Layer0,
your current layoff/layfreeze-setting is set to Object (not Block),
so you are picking the circle inside a block, which is on Layer0.
Check the object type you clicked,
if it is a block reference, check on what layer is the object inside your block: Command BEDIT.
And check your Layoff/Layfreeze settings.
Type in LAYFREEZE/LAYOFF and press [F1] to learn more about these commands and settings.
Sebastian
Message 6 of 8
Goran_Kingkong
I narrowed it down to objects of type 2d polyline. (not in a block reference, nor a block..)
Civil 3d. 2021
Message 7 of 8
cadffm
Jepp, 2D-Polyline are also "complex objects", each vertex (line or arc segment) is one object, "nested" inside a "2D-Polyline" (that how the object typ is defined: [HEADER][VERTEXT][VERTEXT]...[SEQEND])
Check it by command LIST
And you will find Tools to fix this! autocad tool layer seqend
or similar searches
Sebastian
Message 8 of 8
h_s_walker
At the command line type CONVERTPOLY. Choose LIGHT. Next say ALL. This will convert all 2D polylines to normal polylines
Howard Walker
Left Handed and Proud
