Layer Organization for Facility Management Use
austinkb
austinkb
I am looking for best practices when it comes to layer management in an industrial/plant setting. AIA guidelines and others are great for managing construction drawings, but not so much for what I need when it comes to laying out my facility equipment. Is there a set of standards for equipment? For now I am basically labeling everything Q-(Equipment Name)-(Equipment Part).
For example, I have complex industrial equipment (CAD dwgs from the original manufacturer) for multiple production lines. I don't necessarily need a separate layer for each piece, but I also don't want to put everything for 1 piece of equipment on 1 layer/color because it gets difficult to decipher. I also don't want to leave everything on 1 layer and change the colors manually because I know this is bad practice. Seems like I end up with a ton of layers for 1 piece of equipment which is unnecessary since I will move/edit the machinery together. Its not like I'm freezing parts of the equipment while leaving other parts on.
Hope I am making some sense. Anything helps!!
pendean
Community Legend
Community Legend
While you wait... You will need to reach out to your industry groups for guidance, for the most part "cad layer standards" are set by your interactions outside of your organization, inside it you can pretty much do whatever you want, no one really decides that for you.
Pretty much like your equipment manufacturer has chosen to do.
