issue joining curved to straight polylines
i' am drawing a simple polyline shape which contains arcs and lines. When I flick from an arc to a line, the polyline almost doesn't regen properly and creates a funny join, as picture below:
has anyone seen anything like this before and more importantly how to remove it?
Accepted solutions (3)
h_s_walker
Welcome to the Forums
Unfortunately that's the nature of the beast. Closed polylines can sometimes appear that way. There is nothing that can be done about it
Howard Walker
Left Handed and Proud
steven-g
You are using a width, apparently, that's how it works, you could use the fillet command on that junction and use a radius half the width of the polyline which would give it a nice rounded finish>
Or use a different method to create the shape, draw a zero width polyline and use the offset command to create the width and then solid fill.
WarrenGeissler
Depending on your needs, you can get a clean OUTPUT by using lineweights instead of polyline widths:
Left is POLYLINE with WIDTH, Right is POLYLINE with LINEWEIGHTLeft is POLYLINE with WIDTH, Right is POLYLINE with LINEWEIGHT
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
