Is there a fillet setting that removes dimension leaders from the selection cycle
tor3B3UK
tor3B3UK
Is there a fillet setting that removes dimension leaders from the selection cycle? It's annoying when doing the fillet command and it selects the dimension instead of the line undferneath it. I know you can turn off the dimension layer and use toggle to find the line underneath, but these steps shouldn't be necessary since it's impossible to fillet a dimension string, anyway .
pendean
Community Legend
Community Legend
No. You seem to know most methods to address the fix, don't forget about HIDEOBJECTS command too (available in your right-click menu too)
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=GUID-48199A62-90B6-48C6-93E1-5ECF56EAF8B5#:~:tex...
tor3B3UK
Thank you, I appreciate the courteous reply and helpful tip. An option to have a setting that removes objects impossible to be filleted from the selecton cycle seems like a missed opportunity that would make AutoCAD far more user friendly.
pendean
Community Legend
Community Legend
@tor3B3UK wrote:
....seems like a missed opportunity that would make AutoCAD far more user friendly.
You can ask Autodesk for program changes and wish-lists over here where they look for them from us end users:
https://www.autodesk.com/company/contact-us/product-feedback
