Message 1 of 8
- Mute
- Permalink
- Report
Hi Everyone
As the title says, i'm looking for a way to use the data stored in the DISTANCE command (wich you set by using the DIST command) in another command
i would like to use that data in a 'CAL but don't know how to use it
or, for example: you set the distance with DIST and then you want to su that data as the radius for a CIRCLE
how do i tell the CIRCLE command to use the data in DISTANCE?
thanks in advance
