>>>This would happen quite regularly if opening the 3 drawings in
question<<<
RECOVER command, instead of OPEN, will fix any errors. If the files have
XREFs, you need to do the same with each DWG file in the set.
AUDIT command, while in a file, also does the same thing: again, if there
are XREFs in the file, you need to do the same with each.
PURGE the file on occasion to get rid of unnecessary hang-ons may help as
well.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
