Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
INTERNAL ERROR: GEDIT 3.
Message 1 of 24
I don't think somebody allready mentioned
an INTERNAL ERROR: GEDIT 3.
'caus after 2 min (every time) drawings
crash, not funny.
Yesterday I disabled Windows file protection...
But I enabled it again, no change...
LT2002, PII-500Mhz, 256MbRAM, Voodoo Banshee,
Never expirienced any immaterial bugs before
for about 10 months now...
Maybe the DumpEntrie in acltstk.dmp will help
to solve this.
I would appriciate any fast responce very much
Jeroen
[AcadCrashDump1]
ExeTimeDateStamp=0x3AE3FFE5
CrashTimeDateStamp=0x3D522697
Version=15.06
WinVer=0x8930005
DumpType=InternalError
ErrorText=GEDIT 3
ContextFlags=0x10007
SegGs=0x0
SegFs=0x3B
SegEs=0x23
SegDs=0x23
Edi=0x26CEEF0
Esi=0x26CEEEF
Ebx=0xA65199
Edx=0x0
Ecx=0x5
Eax=0x69614D5B
Ebp=0x26CEEC4
Eip=0x7C213D
SegCs=0x1B
EFlags=0x200246
Esp=0x26CDFCC
SegSs=0x23
ReferenceAddr=0x92D7C4
ReferenceName=_WinMain@16
StackWalk0=7BBB85,3C113D,1,SymExport,GetViewportInfo+36BD,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk1=7BB980,3BAB85,1,SymExport,ToolbarArxComm+25B25,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk2=599793,3BA980,1,SymExport,ToolbarArxComm+25920,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk3=599290,198793,1,SymExport,ADCHatchSwichBackAcadViewBkColor+8043,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk4=8AE6D1,198290,1,SymExport,ADCHatchSwichBackAcadViewBkColor+7B40,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk5=8AE622,4AD6D1,1,SymExport,getLastWblockDir+5091,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk6=47EC83,4AD622,1,SymExport,getLastWblockDir+4FE2,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk7=483A23,7DC83,1,SymExport,acedSSSetFirst+38FC3,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk8=6CF412,82A23,1,SymExport,scriptbrk+1BC3,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk9=77E92CA8,2CE412,1,SymExport,acedGetUserFavoritesDir+45D82,C:\Program Files\AutoCAD LT 2002\aclt.exe
StackWalk10=77EA1D77,11CA8,1,SymExport,CreateFileA+11B,C:\WINDOWS\system32\KERNEL32.dll
StackWalk11=2C,20D77,1,SymExport,SetTimerQueueTimer+70,C:\WINDOWS\system32\KERNEL32.dll
Replies (23)
Message 2 of 24
from Autodesk Knowledgebase:
Issue
      When you execute a command in AutoCAD LT® 2002 software, the following
error message is displayed:
      GEDIT 3
Solution
      This error can occur for the following reasons:
        a.. Out of date Iomega Zip® drivers. Ensure you have the latest
Iomega Zip drivers (V3.1+)
        b.. Intel® LANDesk® Client Manager. The only work-around is to
remove this software to test compatibility.
        c.. Unisysn AutoMateT 4 software. The only work-around is to remove
this software completely and test compatibility.
        d.. TEGAM ViGUARD 2002. The only work-around is to disable the
anti-spyware and Internet traffic monitoring option.
      If the error still occurs, try uninstalling any third-party software
in conjunction with AutoCAD LT 2002, and also try starting Windows® in safe
mode to see if any other software that runs at startup is causing a
conflict.
and:
Issue
      The following error occurs during several nested transparent zooms:
      ACAD ERROR ABORT - INTERNAL ERROR: GEDIT 3
      ERROR HANDLER RE-ENTERED EXITING NOW.
      Internal error: gedit 3
      The program then unexpectedly shuts down and prompts you to save your
drawing.
Solution
      If you complete each ZOOM command before starting another zoom, this
error should not recur. However, if the error does recur, save the drawing
when prompted. Then, the next time you open the drawing, allow the program
to recover it.
HTH
Petri Ahava
CAD-Q Finland
Message 3 of 24
Jeroen, try the suggestions at the link below for TS67212. If that
doesn't resolve your error, and you have AutoCAD LT 2002, perhaps the
upcoming Service Pack 2 will resolve it. If THAT doesn't resolve it, you
may have a virus on your PC that is causing it. We have found 4 or 5
cases lately where that turns out to be the cause.
If you have not checked lately, you can sweep your system for a virus
from the link on this page: http://security1.norton.com
I'll send the Service Pack 2 directly to you by separate email.
Error: GEDIT 3
http://support.autodesk.com/getDoc.asp?id=TS67212
j_van_damme wrote:
> Hi,
Bob Felton
Autodesk Product Support, Platform Technology Group
Message 4 of 24
Where can I get a copy of this Service Pack 2 repair. Has anyone had any comments reguarding Windows NT and the GEDIT 3 error problem. We are having GEDIT and slow zoom / pan problems with LT 2002 and all machines running NT. We have tried all the suggestions that Autodesk has recommended to no avail.
Big Dave
Raytheon Infrared Operations.
Message 5 of 24
Dave, I have sent the Service Pack 2 English Unlocked to you by separate
message.
> Big Dave
Bob Felton
Message 6 of 24
Why not put it back in Beta, or Release it, so users can access it without
this happening?
Dean Saadallah
http://www.pendean.com
Expanded Links Page
http://www.pendean.com/lt/links.htm
"Bob Felton (Autodesk Support)" wrote in
message news:[email protected]...
> message.
> > Big Dave
> Bob Felton
Message 7 of 24
hi
i have just installed autocad 2002 lt in my computer and i keep getting the internal error: gedit 3. i guess i need the service pack 2 for 2002 lt. but there isnt any link on the site. i would really appriciate if you can send me the sp2.
thanks alot
architect-
esra 7
Message 8 of 24
There is no SP2... .
Google GEDIT3, it is a conflict on your system with another app, it may or
may not get resolved, only real 100% fix is to move away from LT2002.
Dean Saadallah
http://LTisACAD.blogspot.com
Message 9 of 24
I am having the same problem since reinstall ACADLT2000 on my new hard drive Windows XP
Thank you
Dave
Message 10 of 24
pendean
Community Legend
Community Legend
Fully patch and update LT2000 first.
Message 11 of 24
I have updated it with the same results
Dave
Message 12 of 24
pendean
Community Legend
Community Legend
Do you have any Norton products installed?
What other applications are installed new that were not installed previously? A full list would be helpful.
GEDIT3 errors are all about conflicts with other software: not easy to find but since this is only a new hD installation, you should be able to identify more easily.
Message 13 of 24
That was it, Nortons. Had to put a program exception in Nortons.
Thank you
Dave
Message 14 of 24
pendean
Community Legend
Community Legend
Great: thank you for following up wiht the solution BTW.
Message 15 of 24
I recently replaced the hardrive.  The tech installed Norton360.  Problems persisted until I removed Norton completely and reinstalled McAfee.  I now remember that Norton was a problem in the past.  It does not like ACAD.lt.  Do yourself a favour, dump Norton.  Norton suggested that I turn off the firewall and security and try to use ACAD.  Temporarily turning off Norton was NOT enough.
Hope this helps.
It worked for me.
Message 16 of 24
I need too the Service Pack 2, because my autocad LT2002 have the same problem. (GEDIT 3)
Best regards
Message 17 of 24
pendean
Community Legend
Community Legend
There is no SP2 for LT 2002: you are reading a typo most likely.
Message 18 of 24
ScottHodges
I think you missed the solution gedit 3 is a software conflict, usually antivirus
Message 19 of 24
pendean
Community Legend
Community Legend
LT2002 was snake-bitten: it needs to be buried somewhere and forgotten.
Message 20 of 24
ScottHodges
Never had too many problems with LT 2002, used it until clients wanted all .dwgs in minimum 2010 format. It was the versions between LT 2002 including LT2009 that were troublesome, hence us staying with LT 2002 for 8 years
