I have just installed the latest version of AutoCAD Lt (upgrading from 2008 Lt) and now find that the screen will not display correctly below a horizontal line approx 2/3 of the way down the screen (see attached screen shot). All lines, curves etc below this are truncated, though hatching still displays. Any ideas on how to solve?
Solved by Emmsleys. Go to Solution.
Hi @Anonymous,
Please try applying the update as suggested for AutoCAD LT 2017. Post back int he thread should you continue to have an issue with your screen display.
Thanks.
Following up on your thread, please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Thanks.
Thank you very much - the update so far appears to have resolved all my issues. I have only just had the opportunity to install it so apologise for taking a few days to reply. I am happy again!
Glad you were able to take a few days to test it out and thanks for posting back!
If you have additional questions feel free to post back in the thread or create a new one.
Hi everyone,
I've have recently started having issues with the drawing on my main screen whereby around 2/3 down the screen parts of the drawing disappear. Some lines so show but not all. The PC has been updated wiht the latest BIOS and Nvida drivers buy the IT Team, but this hasn't resolved the issue. Has anyone come across this and any idea how to resolve it ?
@Anonymous What is your secret AutoCAD version as listed in ABOUT command?
And the OS is...?
While we wait... consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort to see if that helps.
