AutoCAD LT Forum
Imported archicad drawing is showing wrong scale
9 REPLIES 9
Message 1 of 10
2800 Views, 9 Replies
I have a dwg made from Archicad but when open a door scales 75,0000 which should be 1500mm.
How do I change the scale?
Louise
9 REPLIES 9
Message 2 of 10
rkmcswain
Did Archicad make the DWG file?
Perhaps it did some scaling before the export.
75,0000 is not a number. Did you mean 750,000? Or 75,000? It makes a difference since 750,000 is 1,500*500, and 75,000 is 1,500*50.
Message 3 of 10
in reply to: rkmcswain
The dwg was made in Archicad first.
The dim is defiantly showing 75,0000 for a door which should be 1500mm
Message 4 of 10
pendean
SCALE command not an option? ALIGN command has a scaling option you can use too.
Message 5 of 10
pendean
75.0000 for in North America, OP wants 1500.00
Message 6 of 10
in reply to: pendean
What do i need to\ do to change this?
Scale or something else?
Message 7 of 10
pendean
SCALE command is explained in HELP if you need a quick refresher on how to use it.
Looks like you need to scale by 20 if you want to go from 75 to 1500, don't you agree?
Message 8 of 10
Thank You, scale factor of 20 did work but my dim for a door is 1500,0000.
You mentioned OP? PREVIOUSLY is this something i need to change too.
I think I'm halfway there.
Message 9 of 10
rkmcswain
Good point. Maybe the forum should let help identify users with a flag, as in below?
Message 10 of 10
All sorted now thank you.
Technology Administrators
