AutoCAD LT Forum
Import hatch
4 REPLIES 4
peterJKBJL
1895 Views, 4 Replies
Import hatch
we installed the new AutocadLT 2021. We would like to add our hatches. We have files with hatches: acad.pat and acadise.pat. We tried to import hatches with some methods. For example import to link via options window - support file search path. The next method was copy our hatch files to C:\Users\admin\AppData\Roaming\Autodesk\AutoCAD LT 2021\R27\enu\Support or
C:\Program Files\Autodesk\AutoCAD LT 2021\Support.
Every these methods don´t works.
We see acad.pat and acadise.pat in Hatch and Gradient/ Hatch Pattern Palette/custom window in Autocad. When we click on these two pat. folders, we see: Error in Pattern file.
Is there any method how we fix it? Do you have any new pat. files with hatches to AutocadLT2021? Is there any different way to import hatches and lines? Thank you.
4 REPLIES 4
vinodkl
in reply to: peterJKBJL
Check if the solutions listed in here works for you:https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
If not, then please attach the .pat so that we can test it from our end🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
hugha
As you are using AutoCAD LT (not AutoCAD) you should copy
ACAD.PAT to ACLT.PAT
and
ACADISO.PAT to ACLTISO.PAT
then try again.
hth,
Hugh Adamson
www.hatchkit.com.au
steven-g
in reply to: hugha
@hugha 👍
That is actually acadlt.pat and acadltiso.pat 😁 but good catch
peterJKBJL
in reply to: hugha
Thank you for your advice. We put code from CADkone to acadlt.pat and acadisolt.pat and we replaced it in appdata,...,..., support folder and now it is ok. This system is really ... .
Technology Administrators
