Hello I need some help, came across a problem with not being to snap lines, polylines or rectangles etc. When I draw a line it has one snap at the end of the line that lets you drag the line to another area but I cannot stretch it same with polylines.
Try this (keyboard input)
ZOOM
#0,0
#500,300
LINE
50,50
200,100
Select this line: Still just one grip?
Sebastian
Actually what's happening is I received a DWG file for an Xref and when ever I draw on this background file it automatically locks my lines up and polylines and rectangles. I cannot stretch them at all its like they become frozen.
If you like a quick answer and perhaps a solution, share your files..
If not, answer my question (please).
If the issue is only at the area you can see the xref:
Move the Xref from pick point on xref object, to *0,0,0
then run my test (see my answer above).
What i want to test: Perhaps you are working in a very high coordinate area
or your objects are very very big (or small).
Use ID and DIST, share the results [F2]
Test it
Sebastian
