This has been happening intermittently but now seems to be permanent. When I slect the Multiline tool, click to place the text box, then click to place the other corner the box ignores the size I set and snaps to as wide as the screen and one line high. It does this in several different drawings so it is not native to one. If I enter text and deselect I can adjust the handles and alter the text.
I have attached a screen shot to show. It doesn't matter how close or far I am zoomed in on the drawing.
For what it's worth I do not like the way the ribbon panel controls handle text, it usually takes multiple tries to get it to change the text height. I usually resort to using the Properties flyout but that adds mutltple steps to the process.
Solved by sthompson1021. Go to Solution.
OK, here is a dwg with the problem. It seems to be consistant across all drawings I have opened. What is confusing is that this just happened without my making any changes, working in a drawing that I have been using for over a month.
When I opened your dwg, your text height was set to 1/8" when I started the MTEXT command. That's why the text box appeared so narrow in model space. When I changed it to 8" it looked better. Like I said earlier, I have had the WYSIWYG setting change on me for no apparent reason. Can't explain why it does it, but it does.
Thanks, that seems to be the answer. It is very weird though because I NEVER enter text height info at the command line and I swear it happened without any intervention on my part during a drawing session, it was fine one minute and wrong the next.
And why is the setting the same in all drawings?
Even I encountered this problem. Here are the steps to correct it:
Dean, while I agree with much of what you are saying, on the text height issue it depends on how you use autocad. For me, I always have text height set to 0 in my text styles because I use single line text more then Mtext and I like to have the prompt for text height. When I use Mtext I just change the height in the text editor. As long as the user is aware of how the system works, it really boils down to his or her preference. As far as the changing system variables, isn't that why we have you
To answer both of you, we do have preset templates with universal standards. We use the same non-annotative font, always set to 0 in Format>Text Style dialog box. Each drawing uses the same base template. Some of these issues and suggestions are things I have never encounted since I do not need to set or alter them.
Somewhere, somehow, the text height variable was changed.
Thanks for all of the suggestions, it's been educational.
Oh yes, I discovered that I can turn ON the text editor toolbox and don't need to use the ribbon or Quick Properties.
But, what if you require Annotative Text for the drawing? Do you have to change it after you create the text box? For this specific set of drawings, I'm specifically required to use Annotative Text for my assignment. Thank you!
I think they patched out that problem. I use annotative text and the WYSIWYG setting and have no problems with the text. Just remember it will change the width of the text box itself depending on what scale you use.
Howard Walker
