I have searched the forum and can't find the answer to this here or anywhere else online. Seems like it would be straight forward but.....
When inserting a view, from the Layout tab>Insert View, how do I set the default scale for that inserted viewport? For example, after I insert a model view into paperspace, I need to right-click in order to choose the scale that I want. I don't want to right-click anymore as it's an extra step that seems like it should be easily avoidable.
I know there is a setting somehow because I work with drawings developed by others and the scales are never the same and are usually what they were using as a default scale in their viewports.
That wasn't working and then based on what you said, I thought something weird was happening. the value I chose was not the one being offered first in the list. It seems like the list was offset or something. I SCALELISTEDIT and reset the list and that fixed everything. Thanks!!
I assume that autocad is picking a scale for me based on what will fit in the paperspace layout, even thought the scale I want to use by default, but can't, will easily fit.
